06-17-2021
07:14
22:58
06-17-2021
07:14
22:58
The picture for the clock option it shows the time in 24hour format but when I'm using it, it has normal 12hour clock. Is there a way to change it? Why show the picture in 24hr clock if its not?
06-18-2021 12:23
06-18-2021 12:23
@8143DS Welcome to the Fitbit Community. Thanks for the details mentioned.
Please confirm, this procedure has been followed to change it:
Hope this helps.
Best Answer06-18-2021 12:23
06-18-2021 12:23
Hope this helps.
Best Answer06-18-2021 13:27
06-18-2021 13:27
06-23-2021 23:12
06-23-2021 23:12
I did this and still doesn’t show 24 hour clock! Will try again
Best Answer06-24-2021 16:45
06-24-2021 16:45
@Missied Welcome to the Fitbit Community. Thanks for the troubleshooting performed.
I'd like you to make sure this procedure was followed and confirm that your Inspire 2 syncs after changing your settings.
Hope this helps.
Best Answer10-23-2022 00:56
10-23-2022 00:56
Only just spotted this - no it didn’t work but have got used to it.
Other issues now with alarms not syncing - just the alarms everything else is fine
