06-21-2020 22:03
06-21-2020 22:03
I cleared my data by accident and now I can't do anything with my Fitbit. I don't have the data code or any information from the box it came in (misplaced it some how) Any suggestions? Thanks
06-22-2020 00:36
06-22-2020 00:36
Try going through the initial setup process again. From the main screen of the app select your profile image at the top left. Then select "set up a device". Choose the Inspire and follow the prompts. Hopefully this will get you working again.
Best Answer06-22-2020 09:13
06-22-2020 09:13
Best Answer06-25-2020 11:57
06-25-2020 11:57
So I tried this but it didn’t work. Initially when I signed up my Inspire, I had a 4 digit code and entered my email address. When I try again it says “ sorry this email address is already in use. I even deleted the app and reinstalled it but nothing worked. I’ll probably just use the Fitbit as a watch.
Best Answer06-25-2020 23:29
06-25-2020 23:29
If it's saying the email is already in use then it suggests that you are trying to create a new fitbit account.
There's no need to do this. You want to login to your existing, original, fitbit account in the app and then add the fitbit as described above. This way you keep all your settings, data, badges etc but if you create a new account then you'd lose all that.
