09-11-2019 06:05
09-11-2019 06:05
This morning I waked 2.85 miles in 39 minutes. The steps are showing as are calories, but the 39 active minutes dropped down to 13 about 15 minutes after my walk, and the walk did not register as exercise. What gives?
09-11-2019 08:55
09-11-2019 08:55
I had a similar problem this AM. Walk not recorded, then active minutes returning to zero from 50 or so. I don’t know how to fix or get a response that would be helpful.
09-12-2019 08:12 - edited 09-12-2019 08:12
Hi. I have the same problem from today.
Active minutes show 0.
Is there any bug being fixed or...?
09-12-2019 08:49
09-12-2019 08:49
09-12-2019 08:53
09-12-2019 08:53
Hi again :).
I contacted the fitbit support, and they gave me the restart solution:
Then the active minutes will be working again
I'll try this as soon as i go home and keep you updated 🙂
09-12-2019 08:57
09-12-2019 08:57
09-12-2019 08:58
09-12-2019 08:58
09-12-2019 10:31
09-12-2019 10:31
09-12-2019 11:10
09-12-2019 11:10
Didn't work for me!
09-17-2019 13:08 - edited 01-01-2020 10:49
Hi @AnnMcD @MPier and @JuliP. nice to see you around. Thanks for reporting the issues with your active minutes and for checking with our team this information.
That's odd! If you're doing activities in the same way, basically same intensity and duration, your active minutes shouldn't vary a lot. Check this information in regards of Active Minutes are gain and follow these steps:
Also I would recommend checking the information for previous activities during different days, to see exactly what are the activities that are giving you active minutes. And confirm if they are also disappearing from previous days. You can go to the Fibit.com Dashboard on the computer or on the browser in your phone, click on Log > Activities > Choose the date and choose to see calories.
Your Active Minutes will be shown with the calories in high intensity level as green lines, as you can see in the picture. Moderate intensity level are shown in yellow lines.
@AnnMcD About the issues that you're having with your active minutes, I'd like to know if your device is always syncing correctly as it happens to me once. That when it tries to sync it shows the information updated, but if the sync doesn't complete or fails the information reverts to the previous data.
Keep me posted!
09-20-2019
06:33
15:10
YojanaFitbit
09-20-2019
06:33
15:10
YojanaFitbit
Still having issues..the other day my 37 active minutes turned into 117
active minutes in about 20 minutes when I was not active.
Today I walked 2.85 miles, and 5,000+ steps in about 35 minutes and my
Fitbit is showing 0 active minutes.
I am very frustrated!
Moderator edit: Removed personal information
09-20-2019 08:33
09-20-2019 08:33
10-05-2019 06:06
10-05-2019 06:06
Did as directed and Active Minutes are not disappearing, but I think they are now running high. This AM showed 15 Active minutes when I got out of bed.
My issue now is thar walks aren't being detected, though miles and Active Minutes are. My walk Thursday and yesterday did not get recorded. My 2.5 mile walk did not initially show up, although about 20 minutes later it registered. Active Minute numbers again look too high.
FRUSTRATED!
10-05-2019 12:34
10-05-2019 12:34
10-22-2019 12:51
10-22-2019 12:51
it turned my 23 to 14, did what's listed here and now it's zero
10-22-2019 14:39
10-22-2019 14:39
