06-13-2019 19:46
06-13-2019 19:46
I have had to reset my inspire HR multiple times since I bought it 30 days ago because I was not getting simplified sleep data. After three resets in a row, it shows simplified sleep data for a few days then reverts back. I never had this issue with my Alta HR and wear it on the same wrist with the same tightness. I’m thinking I need to return this one- seems defective.
Best Answer06-14-2019 02:13
06-14-2019 02:13
Hi @Dink78 I am a little confused! What sleep data are you getting? You should be getting Sleep Stages rather than sleep patterns (which is simplified sleep data). So are you getting the patterns (awake, asleep, restless) or the Stages (awake, REM, light, deep)?
Helen | Western Australia
06-15-2019 09:40
06-15-2019 09:40
Best Answer06-15-2019 18:14 - edited 06-15-2019 18:16
@Dink78 Sleep patterns ARE Simplified data
This is sleep patterns (simplified data) on the left, and Sleep Stages on the right
Sleep patterns (simplified data)
Sleep Stages
06-15-2019 18:26 - edited 06-15-2019 18:29
@Dink78 I couldnt seem to add anything more beneath the images in my last post so here is the rest of it!
I assume you are seeing Sleep Patterns but want to see Sleep Stages
Have you seen THIS Help Article on Sleep Stages? It does give some information, but I am not sure ifnit will help you. The two possibilities I can think of is you are not wearing the Inspire tight enough for it to get a good reading, or for some reason it is not recording your heart rate as well and consistantly as your Alta HR. This may be your unique phisiology doesnt 'match' the way the Inspire measures your heart rate, or it may be something wrong with the Inspire. Have you tried restarting the Inspire several times? (Woops - just looked back at your original post and you have done this already) Give it another try and see how you go over the next few nights. If you still are not getting sleep stages then please come back here.
06-16-2019 06:21
06-16-2019 06:21
