04-10-2019 05:46
04-10-2019 05:46
Just purchased for my daughter tracker dead.. charging over an hour fit bit does not want to turn on? Is it defective or allow more time?
thank you,
04-11-2019 00:07
04-11-2019 00:07
Hi @Paloma1234 Is sounds defective. Try restarting it several times, but if it still wont come on you will need to return it to where you bought it from, or contact Fitbit Support if you got it from the Fitbit online store (link in my signature)
Helen | Western Australia
04-14-2019
09:11
09:25
04-14-2019
09:11
09:25
It's great to see you around @Paloma1234 and @NellyG thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to fix this turning on issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 😉
