10-15-2023 18:12
10-15-2023 18:12
Every time I do a run and enter it manually, it automatically changes it to a different number when I go back to the home screen. For example, today I ran 7 miles, manually loaded all data from the run, saved, and when I went back to the home screen it's showing all the data I loaded (time, etc) but the miles swapped to 4.35. It appears to be swapping between kilometers and miles automatically but incorrectly (if i put the distance in as kilometers under miles it gives me 7 when it switches but vastly throws off the step tracker) and calling it miles. Also there is no longer a function to put distance when using the treadmill selection for manual entry, which is VERY aggravating.
