08-09-2022 16:44
08-09-2022 16:44
My battery is charging well, but at times the indicator shows low charge.
Best Answer08-11-2022 03:30
08-11-2022 03:30
Hi, @Cksabareeshan , are you referring to the battery level shown on the Fitbit itself or in your app? The level shown on the Fitbit should be accurate, and you should charge your device when it shows battery levels below approx 20%.
On your app the battery level shown will be accurate only as of the last sync. So if you haven’t synced your Fitbit since you last charged it, for example, your app will continue to show low battery until the Fitbit is next synced and the battery level is updated.
I hope this helps. Welcome to the forums!
