02-17-2022
11:02
22:51
02-17-2022
11:02
22:51
My battery drains within hours of fully charging it…any ideas why?
02-18-2022 10:01 - edited 02-25-2022 10:05
Hi, welcome to the Fitbit Community forums, @AndreaCollier.
Thank you for sharing all this information about the trouble you've been having with your Inspire 2.
The battery can last up to 10 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours. Please make sure to follow all the recommendations listed in this article.
In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
Hope this helps, I'll be around.
Best Answer02-20-2022 21:03
02-20-2022 21:03
I purchased mine around last year, the battery barely lasts for 4 hours; the major apps have been deactivated too!
Best Answer02-20-2022 22:12
02-20-2022 22:12
02-21-2022 00:12
02-21-2022 00:12
Exactly! Have you tried applying for a replacement since it is still under warranty?
Best Answer02-22-2022 23:14
02-22-2022 23:14
Sorry I meant Xmas 2020 so no it’s no longer under warranty 😣
Best Answer02-25-2022 10:10
02-25-2022 10:10
Hi, thank you for your replies and for sharing these updates. I'm sorry to see that you continue to experience the same inconvenience.
@ShivangiH I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
@AndreaCollier In this case, since you already tried all the steps suggested earlier and you continue to experience the same problem, I recommend that you get in touch with the Customer Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected
Thank you for taking the time to share all your feedback and comments about the product.
See you around.
Best Answer02-27-2022 19:26
02-27-2022 19:26
I got the replacement bit; thank you!
the battery on this lasts for 10 days and up, let's see how long it stays performing.
Best Answer03-04-2022 06:29
03-04-2022 06:29
