11-06-2020 04:06
11-06-2020 04:06
Hi,
I bought a HR Inspire in Dec 30 2019 and the battery life was lasting around 6-7 days; however, for the past week the battery is draining extremely fast. I charged it on Sunday when I noticed that the Fitbit had died, and then had to recharge again last night (Thursday). Since it hadn't registered any steps for Thursday, it had to die on Wednesday at some point for a total of just of 3 days. The charge was completed around 7 pm and when I woke 12 hrs later, the charge was down to 64%. I know that the battery life will decrease over time; however, is this surge normal for a fitbit that is less than a year old.
Thanks.
Best Answer11-06-2020 06:38
11-06-2020 06:38
The same thing just happened to me! When I woke up Thursday, my fitbit still showed end of Wednesday steps and still had Wednesday date. Battery was down to 8%. I rebooted and I was able to fix the date and reset for Thursday but battery is draining fast. Only lasts hours. It literally went from lasting days to hours. Could it be a system error doing this?
Best Answer11-06-2020 13:42
11-06-2020 13:42
I chatted in a help session and asked if the software had been update - no response so thinking no but they are having me recharge to 100 so they take a look at it. At 1 pm, it was down to 47% which means it is only a 24 hr charge on average.
Best Answer11-06-2020 14:04
11-06-2020 14:04
Best Answer11-06-2020 14:34
11-06-2020 14:34
That's exactly what they told me. Fully Charge (left it charging for almost 5 hrs) and then let it drain. Once that happens, I'm to let them know and give my case number. I called around 1pm.
Best Answer11-06-2020 16:05
11-06-2020 16:05
Best Answer11-07-2020 06:35
11-07-2020 06:35
If it was a recent software upgrade to the HR Inspire, I believe that there should be more people reporting; or if they are, they are not members of the community. At this point, I'm leaning towards the fact its just ours. I charged last night, laid it on the table and waiting till it drains. I'll txt them back when it gets down to 0 (70% at the 12 hr mark with no activity)
Best Answer11-07-2020 07:50
11-07-2020 07:50
Best Answer11-07-2020 08:34 - edited 11-07-2020 08:34
I don't believe that you do. As long as its near the phone or device where you loaded the app. I just did a search on Inspire HR Battery Drain and does seem like several others having the same issue but theirs's started about a month ago. Not really sure why synching it multiple times a day would save battery life tho.
Best Answer11-07-2020 20:31
11-07-2020 20:31
Every time you sync they can see what percentage your battery is at throughout the day. They were able to see that my battery was not normal. They are sending me a new one for free. You can choose the exact one you have for free or 50% off a different new one.
Best Answer11-07-2020 20:35
11-07-2020 20:35
Thanks - I chatted late today and the same, they are replacing mine also. I was not offered a different version for 50% off. Glad we were both under warranty 🙂
Best Answer11-08-2020 11:26
11-08-2020 11:26
My battery charge is lasting less then 10 hours for a few days now. What is wrong?
