10-13-2019 09:31
10-13-2019 09:31
I bought my fitbit just over a month ago and was working fine up until wednesday. The screen has gone blank. It will charge and if i wear it it still tracks my steps as can see on my Iphone app. How can I either get this fixed or replaced?
10-13-2019 13:23
10-13-2019 13:23
This just happened to me too.
10-13-2019 15:43
10-13-2019 15:43
Just happened to me
10-13-2019 18:00
10-13-2019 18:00
This has happened to me a couple of times, lasts for like 20 mins or so but eventually goes back to normal.
10-13-2019 19:02
10-13-2019 19:02
Me too. Black screen. Had mine for just over 4 weeks as well. What gives?
10-14-2019 04:00
10-14-2019 04:00
Mine just did this yesterday. It had done it a few times for short intervals but yesterday morning it went blank after being on the charger an has not resolved itself.
What is going on?
10-14-2019 04:07
10-14-2019 04:07
Yes mine had been charging as well.
10-14-2019 04:19
10-14-2019 04:19
Ok, so I chatted with costumer service. They had me plug my Fitbit back to the charger and hold the side button done for over 5 seconds. It took two tries but then it rebooted my Fitbit and now it's back to normal. Hope this is helpful.
10-14-2019 04:27
10-14-2019 04:27
Found the restart instructions as you were posting. Took me three tries but mine is now functioning correctly
Thanks for posting.
10-14-2019 04:30
10-14-2019 04:30
10-14-2019 05:14
10-14-2019 05:14
10-14-2019 09:22
10-14-2019 09:22
Does your data come back after resetting it?
10-14-2019 09:27
10-14-2019 09:27
According to the help file I read, the data is not deleted.
10-14-2019 09:32
10-14-2019 09:32
Thanks. Ive not even had it for 2 months and this is the 2nd time its done it. First time i needed an app update but not this time. Ive got 27% battery so not sure why its done it
