06-23-2020
07:03
21:51
RicardoFitbit
06-23-2020
07:03
21:51
RicardoFitbit
My Inspire HR can no longer hold a sustained bluetooth connection with my phone. For example, if I go for a run I can only maintain a connection for 2-3 seconds at a time, and it might successfully reconnect once or twice during my run but not long enough to make any sort of sensible map. I also no longer receive text alerts. It does still sync fairly reliably, though.
For a long time I blamed my phone, an iPhone7, but I recently switched to a Pixel 3 and it's still not working, so it's clearly not my phone.
I've tried:
Making sure both my phone and Fitbit are fully charged
Restarting my Fitbit
Restarting my phone
Updating the app
Clearing the bluetooth connection on the phone and reconnecting
Making sure Fitbit is the only app running
Any other suggestions??
Best Answer06-25-2020 21:50
06-25-2020 21:50
Hi @blyne80, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before to posting over here. To better assist you with this and to further investigate, can you please let me know when was the first time you experienced this issue and how many times since then? Do you use another Bluetooth device at the same time you're using your Inspire HR? In the meantime I receive your answers, please try the following steps:
Looking forward to your reply.
Best Answer06-26-2020 06:35
06-26-2020 06:35
Hi Ricardo, Thanks for getting back to me.
This started happening sporadically in February (sometimes it would work fine, sometimes I'd get a wonky map), and in April it had gotten to the point where it never worked. Since April it's happened about 40 times (every time I run). I don't use any other bluetooth devices while running.
I'll try your troubleshooting suggestions and report back. Thanks!
Best Answer07-03-2020 14:34
07-03-2020 14:34
Hi Ricardo - I tried you suggestion of reinstalling, but unfortunately it did not work 😞 Do you have any further suggestions?
Best Answer07-03-2020 17:11
07-03-2020 17:11
Your reply is appreciated @blyne80.
I'm sorry to know that you're still experiencing some connection difficulties with your Inspire HR and your Google Pixel 3. Please follow the next steps and let me know if the issue persists:
Don't hesitate to ask me any additional questions you may have, I'll be around.
