07-12-2021 21:29
07-12-2021 21:29
Can I get a replacement free loop for the wristband band
The free loop is the small rubber loop on the wristband that you tuck the free end of the wristband into. It keeps the free end from flapping around which could cause the wristband to become unsecured and the Fitbit could fall off.
I could get a whole new wristband but all I need it the small loop.
Best Answer07-12-2021 21:33
07-12-2021 21:33
Hi @kipmc7 If you have a dollar store, go into the hair products section and look at the small pony tail bands. They are better than rubber bands, generally made of silicon and some are clear. One of those tiny things ought to work well as your loop. See if you can find those.
07-12-2021 21:33
07-12-2021 21:33
