09-10-2022 13:20
09-10-2022 13:20
Can I switch to my iPad for syncing instead of my mobile phone. If so how? The cell is with my husband most of the time now.
09-10-2022 16:52
09-10-2022 16:52
You absolutely can @TIger415
I have my fitbit app installed on my iPad and it syncs great. Just install the Fitbit App on your iPad by finding the app in the Apple App Store. Once it’s downloaded just sign in as you normally would with your email address and password. Turn on your Bluetooth then manually sync your Inspire. You will get a pair request banner at the top…just tap fix it to get it paired with your Bluetooth.
To avoid syncing issues I would unpair your Inspire from the phone and remove the Fitbit App from the phone as well.
As long as your iPad is compatible with the Fitbit App it will work great. It must be an iPad iOS 14 or higher: https://www.fitbit.com/global/us/technology/compatible-devices
😃 I hope this helps and provides you with the best answer to your question. Please let me know how it went.
