Can NOT get the screen to scroll at all ☹️
i just got my new inspire and it WILL NOT let me scroll or tap the screen.. It’s show time,HR,steps and txt but I can’t scroll or tap anything on..
Am I just dumb.. Please HELP!!! 😀😀
3 REPLIES 3
@HBgrl13, of course it is possible that your Fitbit is defective... It is also possible that you haven’t yet got the knack!
I have to say that I have intermittent issues with my phone, and my son says I have ‘zombie fingers’ because sometimes no matter how much I tap or swipe nothing works... But I know my phone works fine.  I would say let someone else try and see what happens... if they still can’t make it swip or react when tapped, then try the restart procedure:
  1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  2. Hold the other end of the charging cable near the port on the back of the tracker until it attaches magnetically. The pins on the charging cable must connect securely with the port.
  3. Press and hold the button on your tracker for 5 seconds.
  4. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
Your tracker should now work normally.
If it still won’t react to your taps or swipes, then ask a family member, friend or neighbour to try - maybe you have zombie fingers!
If your Fitbit is still not reacting, then you should either take it back where you bought it for exchange (that is usually the quickest option for a new Fitbit) or get in touch with Fitbit Customer Service on contact.fitbit.com
I hope this helps.  Welcome to the forums!
ahhh yes the zombie finger.. i did have my neighbors try and still
nothing..tried the restart and nothing soooo fitbit is going to replace it since i literally got
it yesterday..
Sent from my iPhone
@HBgrl13 , good news!  Glad to hear that Customer Services is sorting this out for you.  What you have experienced is unusual (unless you have zombie fingers like me) but it does happen!
I am sure that you will love your new Inspire HR!
