03-22-2019 19:54
03-22-2019 19:54
I have done everything which was suggested online. Bought a new Inspire HR ... had the one and the Alta in the past and these set up easily with no problem. My phone just keeps searching for device. One article says to put the dongle into the computer. My box had NO dongle in it. Was it supposed to??
I tried turning my bluetooth on and off, turned the Inspire off and started again, but no connection, no syncing ... just keeps searching. Any ideas how to get this to work??
Best Answer03-22-2019 20:25
03-22-2019 20:25
Hi @mbmadeline No, a dongle is not supplied as so few people need them these days. They are available from the fitbit store at a very small cost if you do need one. What phone are you using? Is it on the Supported Devices List?
Try THIS Help Article on set up issues.
Helen | Western Australia
Best Answer03-23-2019 08:06
03-23-2019 08:06
Thank you ... it was actually my error. I was setting up an Inspire when I bought the fitbit charge 3. Not sure which is better. Working now. Next question ... on the available clock faces ... the one that says "heavy stats" What is the bottom symbol/figure mean It has a 1,3 Tried googling an answer and can't find what this stat is. Thank you for taking the time to answer. Any thoughts whether the charge 3 or new Inspire HR is better in case I should return it; thought I bought the new one.
Best Answer03-23-2019 09:06
03-23-2019 09:06
1st item is steps, second item is calories, third item is mileage.
