Can't charge my Inspire 2
I have a inspire 2. I lost the charger. I bought one on eBay but it doesn't fit. I was wondering if there is a different charger for a Inspire 2 HR and Inspire 2.
3 REPLIES 3
Hi @33winchester  the charging cable for the Inspire 2 can be found here at the Fitbit Store - click to view. There was an Inspire HR and an Inspire, but they were before the Inspire 2. There is no Inspire 2 HR. When possible, buy from an authorized retailer, so you can return it if there is a problem. The chargers have a warranty, too.
Stepping in the U.S.A. since September 2013. Android 14
My order form said it was Fit bit inspire 2 heart rate monitor. Now is that same as Fit bit inspire 2?
Get Outlook for Android<>
Yes, @33winchester  the Inspire 2 has a heart rate monitor in it. The old Inspire HR had a heart rate monitor, but the Inspire did not. You have the newer version.
