06-25-2022
07:32
22:19
06-25-2022
07:32
22:19
I set my first alarms on my Inspire 2 about a month ago; there are 5 of those “first” alarms. I have been able to add a couple new ones but the 5 old, “first”alarms can’t be deleted, edited, or otherwise used. I have tried every suggestion in the threads for removing them with no luck: gone into my profile on the app, tried swiping up on the tracker, turned off Bluetooth, etc.
How do I remove or edit them so I can clean up my apps AND so I don’t get the 8 alarm limit message? Thank you!
06-25-2022 12:04 - edited 11-16-2023 03:17
Hi there, @1gamechanger. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out.
In addition to the steps you've done so far, please try the following:
Hope this helps.
Hope this helps.
