11-12-2025
06:45
06:41
MaCrisGBFitbit
11-12-2025
06:45
06:41
MaCrisGBFitbit
I used to be able to edit my sleep when my watch was off and missed some sleep time. This feature no longer works, and it was very helpful to be able to combine gaps. Now you can change the time but it will not recalculate the score. Please bring it back..
11-12-2025 08:17
11-12-2025 08:17
Same thing. Pretty often is doesn't count my early sleep, I must move around too much while settling in. I reset my start time (based on the last thing I heard on TV) and it used to populate it with sleep cycles and score. Now, nothing. I was wondering if it has anything to do with my not migrating to Google yet?
11-12-2025 09:44
11-12-2025 09:44
11-13-2025 06:40
11-13-2025 06:40
Hi @SusanSimp and @gailmail5! Welcome to the Fitbit Community! It's great to have you here!
Thanks so much for sharing that you can't edit your sleep logging. I'll do my best to help you with that.
I suggest to verify if the Fitbit app is up to date, the current version is 4.56, if you have any updates available this may be the reason.
Best Answer11-13-2025 16:10
11-13-2025 16:10
Best Answer11-16-2025 08:09
11-16-2025 08:09
Hello @SusanSimp! I'm glad to hear you've updated your app.
Let me invite you to our Health & Wellness board where you can make new friends, create topics and share your experience while reaching your goals.
Best Answer11-16-2025 13:02 - edited 11-30-2025 07:19
Hi! I'm on version 4.56.fitbit-mobile, and last night I slept quite badly and it recorded no sleep at all. I added it manually and it did give me the basic stats, since it was less than 3 hours. I did try to edit my sleep time, because heart rate indicated I may have fallen asleep earlier than what I added. It didn't adjust the stats at all.
11-30-2025 06:22
11-30-2025 06:22
It’s still not working. Others are having the same issue. Seems the app is broken in this key are. What is the status?
11-30-2025 06:52
11-30-2025 06:52
It’s still not working. Others are having the same issue. Seems the app is broken in this key are. What is the status? Thanks!
