02-01-2020 00:02
02-01-2020 00:02
Hi,
Got my first Fitbit, an Inspire HR and want to turn on the 24 hour heart rate monitor but can’t seem to find the setting in the app. It is set to on on the device. I go to today and then my profile pic on the app, select the device but then there’s no heart rate setting.
Can someone help?
02-01-2020 10:43
02-01-2020 10:43
If you set in on the fitbit, there's nothing else to set. That's where you set it on or off.
02-01-2020 10:43
02-01-2020 10:43
02-01-2020 11:54
02-01-2020 11:54
Ok thanks, looks like it’s just not working then 😞
02-02-2020 16:34
02-02-2020 16:34
I feel Fitbit speaks foreign language.
My heart rate readings just stopped 21st November.
12 emails later I still can't follow their instructions.
Everything else is working.
How do I do check heart-rate tracking is enabled on my Fitbit device?
02-02-2020 17:47
02-02-2020 17:47
@JuliaBerryI think you are looking on phone app instead of on the fitbit itself.
Assuming you have Inspire HR, from clock face, scroll up (swipe down) to 'Settings' (gear icon); tap that and scroll up or down to "Heart Rate'; tap to turn on or off.
02-02-2020 23:07
02-02-2020 23:07
Hi Julia,
Best to focus on the gear icon on the watch, scroll up (finger down) a few times past exercise till you find the gear icon. If you’re still struggling, there’s a YouTube video on setting up your device that shows it.
Hope this helps,
Sam
02-03-2020 05:38
02-03-2020 05:38
Thank you so much for your quick reply.
I am now sorted. YEY!!!!
02-03-2020 05:42
02-03-2020 05:42
Thank you. I forget about UTUBE, and yet I've found it so useful at other times.
I'm very much a visual learner. More so the older and more senile I get.
02-03-2020 08:07
02-03-2020 08:07
Any thought why heart rate is not getting recorded/tracked in app regularly? Last entry recored was Jan 22... nothing since. Hmm
02-03-2020 09:43
02-03-2020 09:43
Sounds like a syncing issue, I can recommend Fitbit twitter support for quick responses to an issue like that.
02-03-2020 12:18
02-03-2020 12:18
this works
02-04-2020 11:07
02-04-2020 11:07
I don't have syncing issues with othef functionalities.... is that not odd?
02-04-2020 11:18
02-04-2020 11:18
02-04-2020 12:24
02-04-2020 12:24
What worked Kerry? Twitter fitbit support?
Dan
02-04-2020 12:57
02-04-2020 12:57
02-04-2020 13:23
02-04-2020 13:23
Yeah that does sound odd Dan, when I read other troubleshooting sites I saw people have success with wiping the data on the device and reconnecting, some historical data may be lost though. Before doing that though probably best to try Fitbit support.
02-04-2020 13:39
02-04-2020 13:39
03-09-2020 18:03
03-09-2020 18:03
I found the heart rate setting on my Versa under the settings gear icon. It was set "ON"
I still have no green lights and no heart rate reading; The "BPM is off" appears on my Versa screen.
I've powered down several times without any change.
03-14-2020 10:06
03-14-2020 10:06
Sounds broken I’m afraid. I had one replaced, they have an efficient service. Start by logging a support ticket with them.
03-14-2020 10:28
03-14-2020 10:28
