02-02-2020
20:20
09:18
AlvaroFitbit
02-02-2020
20:20
09:18
AlvaroFitbit
I have ben given an Inspire HR.
It won't pair with my iPhone or iPad. Have tried everything you recommend here.
A quick look in Community suggests that this is a fairly common problem.
OK, I say, I'll use the cable and go desktop. Let's see fitbit.com/setup ---- ah, a 404!
Have you guys given up?
02-03-2020
08:03
09:23
AlvaroFitbit
02-03-2020
08:03
09:23
AlvaroFitbit
I think I have a similar problem. I'm using my Windows 7 desktop PC and FitBit Connect to attempt to setup my new (never used) Inspire HR. However, the FitBit Connect application doesn't even have Inspire HR listed as a model to select (to start the setup process.) This is the first forum entry I have seen that is even close to my issue.
02-03-2020 09:43
02-03-2020 09:43
@TimInBC @Privacyisfake Welcome! It's good that the community is growing!
Let me help you setting up your Inspire HR and thank you for troubleshooting this issue. You can try the following:
Let me know how it goes.
02-03-2020 18:56
02-03-2020 18:56
I think you're missing the key component here. In the Windows desktop app - the FitBit Inspire/Inspire HR is not even in the application. When you are setting up the FitBit for the first time and it asks to select which FitBit model you have - it is NOT in the application itself. There is an entire list of FitBits but the Inspire line is not one of them.
02-03-2020 18:58
02-03-2020 18:58
02-04-2020 09:21
02-04-2020 09:21
I cant sync my Inspire HR to my Samsung phone. I set it up ok, it synced and now nothing. Not registering any steps etc. When I try to sync it says " device not found". I've tried all the recommendations to no avail. Have I purchased a dud?
