05-24-2019
16:16
05:41
LuciaFitbit
05-24-2019
16:16
05:41
LuciaFitbit
hi
I just buy new inspire hr, when i try to install the apps, there were nothing showing up in my devices. Now i accidently delete my apps and when i try to install back the code doesnt even showing up from my inspire hr😭😭
Moderator edit: Title and format
Best Answer05-24-2019 19:44
05-24-2019 19:44
Hi @Kas88 What phone are you using to connect to? Is it on the Supported Devices List?
Helen | Western Australia
Best Answer05-25-2019 05:13
05-25-2019 05:13
06:48
08:10
05-25-2019
06:48
08:10
Hi @Kas88, welcome to the Fitbit Communit Forums! Thank you for your effort trying to solve this situation. If you are not able to access any of the functions of the tracker, that means that it is no longer paired with your account. Therefore you need to set it up again.
You mentioned that you have a Samsung J7. At the moment this model is still not listed as a compatible device. Although we can not guarantee a stable connection, you can try following these steps, in order to pair your tracker again: Why can't I set up my Fitbit device?
Please try them out and let me know if it worked!
@NellyG thanks for bringing this up to our attention.
