10-12-2020 08:06
10-12-2020 08:06
Hi
I can’t see all the text in the chat in challenges. I only see the first 3-4 words of a message.
09:24
07:51
10-13-2020
09:24
07:51
@Siobhán It's great to see you in the Community!
Let me help you with your chat text not showing correctly on your Fitbit app. Which phone are you using? Are you using a large font on you phone's settings? If this is the case then make sure you change it back to a normal size font and check the chat again. Also try logging out from the app, restart your phone and log back in. If the issue persists please share a screenshot of what you are seeing on your phone.
I look forward to your reply.
Best Answer10-13-2020 10:52
10-13-2020 10:52
Best Answer10-16-2020 00:42
10-16-2020 00:42
I have tried all that you have suggested. I am using an iPhone 8.
Best Answer01-18-2021 11:42
01-18-2021 11:42
Has there been any resolution to this issue? I’ve seen it on a number of forums but can’t find an answer on how to fix? Thanks
Best Answer01-18-2021 12:16
01-18-2021 12:16
Best Answer01-18-2021 14:02
01-18-2021 14:02
Thanks Siobhán 😊
That’s a bit of a pain 😂
