10-18-2022
12:48
21:04
10-18-2022
12:48
21:04
Alarm setting on the fitbit Inspire 2 says to install Alarms in the mobile app, but the mobile app says Alarms is installed on the fitbit. How to resolve this to use Alarms on the fitbit?
10-26-2022 15:34
10-26-2022 15:34
No luck here either with the steps.
10-26-2022 15:56
10-26-2022 15:56
10-26-2022 17:58
10-26-2022 17:58
Same problem! Started recently. Nothing fixes it.
10-26-2022 18:56
10-26-2022 18:56
Hi everybody! thank you for your reports and efforts.
Our team has been informed and they are looking into this. They'll work on a solution for it.
Should I receive further information, I'll be more than glad to let you all know over here.
I appreciate your patience.
Hope this gets solved soon.
See you around.
10-27-2022 00:09
10-27-2022 00:09
Ghost alarms still there for me :-(.
10-27-2022 00:26
10-27-2022 00:26
Thankyou!
please ensure this is a priority as it’s the reason why a lot of us purchased the fitbits in the first place.
Please advise a timeframe for this to be fixed.Your response is very ambiguous.
10-27-2022 04:15
10-27-2022 04:15
So do we ….could you report back to us every few days so we’re in the loop?
10-27-2022 04:16
10-27-2022 04:16
My thoughts exactly!
10-27-2022 07:24
10-27-2022 07:24
10-27-2022 08:51
10-27-2022 08:51
Yup - same issue here. The app was updated a couple of days ago but did not fix the issue.
I did notice that the alarms still worked by making certain that they are active on the Fitbit itself. Still - NOT working as it should!
I wish they would at least tell their "tech support" people this is a known issue instead of wasting everyone's time on the phone with them making worthless adjustments to the settings.
10-27-2022 18:13
10-27-2022 18:13
I’m having the same issue!
10-27-2022 18:20 - edited 10-27-2022 18:46
Hi everyone! I merged these 2 threads to keep the Community in order and to keep everybody updated as our team is aware of this and are working on a solution.
I'll be updating the thread, should I receive further information regarding this.
Thank you for your understanding
10-28-2022 08:22
10-28-2022 08:22
Is there a time frame ….few days? Weeks? Would be good to know
10-29-2022 22:57
10-29-2022 22:57
I have the same syncing problem. However I just found out that when I add a new alarm to the app, it does show up on my Fitbit even though the app shows it's not synced yet. I had to log off and logged in again after adding before it would show on my Fitbit.
10-30-2022 05:37
10-30-2022 05:37
Hi…I’ve updated using the 3.69 version and the problem is still there……everything syncing except the alarms. In the app can set new alarm times but they duplicate and don’t sync & the only way to get them to work is to keep checking they are on/off on the actual watch
10-30-2022 11:42
10-30-2022 11:42
Same issue. Everything except alarm is syncing on my inspire 2. Duplicated alarm on its own and shows death spiral of syncing. Created an account specifically to post on this issue.
10-30-2022 12:42
10-30-2022 12:42
You’d think with so many users having the same issue, they would fix it soon!
10-31-2022 08:37
10-31-2022 08:37
I think it is FINALLY fixed!
10-31-2022 10:15
10-31-2022 10:15
You are right, thanks for the heads-up!
10-31-2022 12:01
10-31-2022 12:01
Fixed without an app update even. Though I did install a new iOS yesterday, so I did change something in the total setup.
