Can you turn off the auto turn on ?
ANSWERED
My tracker is constantly flicking the screen on with wrist movements.  I've got it on my non dominant , higher up my wrist but it still does it . Tis annoying because it buzzes everytime the screen comes on and it's a waste of battery . Can't it be triggered just by a tap and not simple movement.  Thanks ♥️
1 BEST ANSWER
Accepted Solutions
@Idriscadras A warm welcome to the Community! Thank you for your message.
If you want for the display not to turn on when moving the wrist, there are some options that you could do.
You could place the Inspire 2 in Don't disturb mode.
When the do not disturb setting is on:
  • Notifications, goal celebrations, and reminders are muted.
  • The do not disturb icon
     illuminates in quick settings.
You could also put the Inspire 2 in Clip mode.
To switch between On Wrist  and On Clip  mode, tap the setting > tap On Clip to confirm.
Note that when Inspire 2 is set to On Clip , certain features are turned off, including heart-rate tracking, automatic exercise tracking, and Active Zone Minutes.
Or you could turn the Screen wake off. (Lightbulb)
Swipe the clock face down, and see the quick settings. Tap on any setting that you want to change to set it up .
Hope it helps
2 REPLIES 2
Hope it helps
Ooo thank you, yes this helps an awful lot 👍
