04-07-2019 16:40 - last edited on 07-01-2020 20:52 by LiliyaFitbit
My fitbit inspire hr wouldn't restart after I press and hold the left button on the device for five seconds while its on charge. The smilie face just doesn't appear. Anyone else have this issue?
04-07-2019 16:46
04-07-2019 16:46
Hi @bwa35, are you sure that you're locking the device in place when you place it on the charger?
one cruise ship at a time!04-07-2019 16:52
04-07-2019 16:52
yes I'm sure it's on charge, because the screen shows the charging percentage when I press and hold the side button.
04-19-2019 09:22
04-19-2019 09:22
I am also having this issue. And the battery life is terrible even after changing the watch face.
07-17-2019 13:13
07-17-2019 13:13
Did you ever get yours to restart? I am having the same problem right now. I’m noticing a lack of helpful information.
07-17-2019 14:37
07-17-2019 14:37
I'm having the same problem. This past update caused more problems than fixing them.
07-17-2019 15:29
07-17-2019 15:29
I couldn’t get mine to even update. I’ve been having troubles syncing too. I was hoping restarting it would help 😕
07-17-2019 17:22
07-17-2019 17:22
It finally worked after plugging it in, taking off the case around the screen, letting it charge all the way. Now I’m debating if I should update it or not 😕
10-21-2019 05:51
10-21-2019 05:51
Hey, it must be because the pins wouldn't make contact correctly. I don't think a software update would trouble you regarding recharge.
05-14-2020 16:08
05-14-2020 16:08
How do I lock it in place? It just attaches magnetically.
05-15-2020 17:49
05-15-2020 17:49
I had the same problem. I couldn't get my Inspire to restart. Here is what I did:
If you wait until the Fitbit Logo and "www.fitbit.com/setup" shows up, you've waited too long. Disconnect the charger and start again.
05-15-2020 18:12
05-15-2020 18:12
This worked - thank you so much!!
05-15-2020 20:44
05-15-2020 20:44
I was finally able to do this, but I had to fully charge the Fitbit first, even though it had a 69% charge.
07-30-2020 12:42
07-30-2020 12:42
I had some luck with moving the charger from my computer to a plug-in USB instead. It finally re-set after 3-4 tries.
08-13-2020 21:42
08-13-2020 21:42
the Fitbit Logo and "www.fitbit.com/setup" shows up immediately I press the button. 5 sec hold does nothing. Diamond of dots stays on the whole time. with www.fitbit.com/setup scrolling underneath.
08-28-2022 19:06
08-28-2022 19:06
Didn’t work. It doesn’t even show the charging ststusy
09-28-2022 21:43
09-28-2022 21:43
Same here. If I plug it in, nothing turns on and it actually gets very warm rather quickly. Holding it for 5 seconds does nothing.
