Cant see heart rate whilst exercising on inspire HR
I cant see my heart rate when im out cycling or such like. When I track exercise it only shows time and distance on the watch.
Is there a way to customize this so i can see heart rate as well as distance?
Would be useful to see so Im not over/under doing it. Currently I can only wait untill i've finished and then look on the app.
1 REPLY 1
@Themoo1   I am going to give you the best answer that I can -- I have a Versa on my account and I can't add an Inspire HR without removing my Versa.
The Inspire HR Manual states that you can see three real time stats of your choice.  You can set the top one and the bottom one, then swipe the middle one throughout all the stats during exercise.  When I set this on a Versa, there is a gear icon on each exercise choice.  The Inspire HR manual says you make this adjustment on the device itself, in each exercise -- I'm just not sure if there is a gear icon or some other icon to get you to the Settings.
Not the answer I really wanted to give, but a better answer than swipe and tap in every possible direction until you find it.
Laurie | Maryland
