11-05-2019 16:32 - last edited on 11-08-2019 13:08 by LiliyaFitbit
can you change the way your clock faces
Best Answer11-05-2019 20:01
11-05-2019 20:01
Yes, there are a few clock faces oriented either way.
How do I change my clock face?
To change your clock face:
01-29-2020 21:47
01-29-2020 21:47
That doesn't work for the Inspire. There are none that are compatible. There has to be another way
02-11-2020 21:16
02-11-2020 21:16
I can't find one that works with fitbit inspire hr
I just need at least normal put together time
Time 12:00
Date. fed 11
Steps. 10,000
♡ 64
See simple , just freaking simple.
02-25-2020 04:13
02-25-2020 04:13
Sad, there were some before, but not anymore. 🤔😔
06-21-2020 16:03
06-21-2020 16:03
Do you know what’s the face that comes preinstalled as the factory default with the Inspire HR please? I have been able to change the face, but I would like to go back to the default one.
Best Answer07-07-2020 22:33
07-07-2020 22:33
simple stats
Best Answer08-25-2020 05:10
08-25-2020 05:10
I was unable to get to the stage of installing a clock face. I would go to my account, click on clocks, go to all clocks, click on the one that I wanted, and then it would either load forever, or sometimes take a long time just for it to say 'unable to connect to Inspire HR'. I have tried resetting the fitbit, as well as making sure I have good internet, but nothing seems to help. Would love some help if you can...
Best Answer09-28-2020 08:27
09-28-2020 08:27
How did you change the face I can't find any that are compatible and have been trying everything to find out how to do it please help
Best Answer09-28-2020 08:29
09-28-2020 08:29
How were you able to change your clock face I have been trying everything but I can't find one that is compatible with the inspire if you could help that would be amazing I would being internally grateful
