06-19-2022
05:25
22:19
06-19-2022
05:25
22:19
Just purchased a Fitbit Inspire 2 to replace my Charge 3. Will I lose my current data when I change devices?
06-19-2022 07:26
06-19-2022 07:26
Hello @Pastorina and welcome to the Community. Data is synced to your Fitbit account. Make sure you sync your Charge 3 before setting up your Inspire 2. You can't have both devices on your account at the same time. You can either remove your Charge 3 before starting or you can just tap on your profile picture, then + Set Up a Device. Your app will ask you if you want to switch devices.
After your Inspire 2 is all set up, you should also remove your Charge 3 from the Bluetooth devices on your phone.
Laurie | Maryland
Best Answer06-19-2022 07:26
06-19-2022 07:26
Laurie | Maryland
