01-03-2020 23:14
01-03-2020 23:14
01-04-2020 01:54
01-04-2020 01:54
You can do this via the web interface at https://www.fitbit.com/settings/profile
There are 3 unit settings for length, weight and water and you can choose between metric and imperial options for each. e.g. for length choose feet/inches for imperial and centimetres for metric.
Once changed and saved, you'll need to sync to update your fitbit.
01-04-2020 01:54
01-04-2020 01:54
01-07-2020 18:52
01-07-2020 18:52
Awesome!! Thanks so much. Much easier than converting everything!! 👍
