Charge 3 Versus Inspire HR
My Charge 2 recently died on me and I am debating whether or not to replace with the Charge 3 or Inspire HR. I rely on the device for calorie and step counting.
Would greatly appreciate any advice or feedback anyone can offer on either of these devices.
Thank You!!!
1 REPLY 1
Hi @Tinalou  well it is hard to advise someone on this as so much is personal preference. For me, (having had both a charge 3 and an Inspire HR) I would go for the Inspire HR, simply because I find it more comfortable, and you get much the same stats etc on it. However if you are used to the larger Charge 2 you might find the Charge 3 a better fit as it is a similar size. The Inspire HR doesnt count floors while the Charge 3 does, but that has no weight for me as I dont find floor count particularly accurate on any device, so its absence is not an issue. The Charge 3 with the bigger screen is probably easier to read if sight is an issue. I found both my devices worked well. I liked the look of both devices on my wrist. Can you go to a retail store and try both on?
Community Council Member
Helen | Western Australia
