04-17-2019 04:10
04-17-2019 04:10
I only had my Inspire HR a few weeks. I love the soft band, but after I removed the Fitbit to charge it noticed that the metal piece (quick release lever) was stuck to my wrist. Now I'm afraid the band will fall off or I won't be able to change it.
04-17-2019 17:32
04-17-2019 17:32
Hello @Gargie! Nice to see you on the Fitbit Community forums. I'm sorry to hear that your Inspire HR's band fell apart. Thanks for the détails you provided they are really helpful. I have created a case for you at our Support Department so they can help you with. They will be in contact with you shortly, please keep an eye on your inbox.
Please let me know if there is anything else I can do for you. 🤗
11-03-2019 13:26
11-03-2019 13:26
I just had the same issue and now can’t get the band off!!! Help!
09-25-2020 10:59
09-25-2020 10:59
I was putting my Fitbit inspire on I only got it today and I got mad and took it off hard and the clip that goes into the holes broke off and now I can’t wear my Fitbit 😢😢😢
