Clock face always on suggestion for Inspire HR
I know that a clockface always on feature is under consideration by FitBit. I also understand an always on mode eats battery. However I would like to suggest this feature to be able to be set for at least an hour duration. I am using my Inspire as a watch replacement. In meetings, I need to glance down at the time to keep the pace without doing an obvious watch check, which can appear rude. So does an obvious hit of the left button or raising my wrist to look at the time to activate a 60sec always on. Just would like to pop that always on feature on before I walk into my meeting room.
Thanks for this Community Forum!
1 REPLY 1
@CernerinDC Welcome to the Fitbit Community! I hope you're doing well!
Thank you for your inquiry. You can share your idea in our Feature Suggestions board even in the specific suggestion you are mentioning or create a new one. The more votes an idea gets the more likely the developers will try to implement it.
I'll be around.
Alvaro | Community Moderator
