Clock faces for fitbit inspire hr?
ANSWERED
I am wondering if I can change the clock face on my recently purchased fitbit inspire hr? I tried looking at the clock faces in the phone app but having a hard time finding one for this model.
If any one can help with some info, that will be great.Thanks
1 BEST ANSWER
Accepted Solutions
First look in the top right hand corner of the dash board of the fitbit app and there will be a pic of your fitbit click that from there there will be an icon that says clock faces than click it than you can set the clock face.
6 REPLIES 6
Thanks, I tried that but can't find a clock face for Fitbit inspire hr.
Thanks, I already tried that but can't find the ones that works with Fitbit hr.
Well here is a tutorial https://youtu.be/gx_6MzXMh7g
Here is how to change the clock face on your Fitbit fitness tracker watch. If you have a Fitbit and you want to change the clock face to a different one, it is very easy to change the clock face using the Fitbit app on your phone. It also allows you to save five different clock faces, so if you ...
Thank you!
same it is just blank
