07-02-2022
19:06
22:19
07-02-2022
19:06
22:19
About a week ago I realized that there was a little bit of condensation inside the screen of my Fitbit just below the time. It makes it very hard to see my steps or heart rate. I put it in rice for 48 hours and did a hard reset. Still there- actually, it got worse. I even placed it over a vent hoping the cold air would drive out the wetness. I’m very careful with it…it doesn’t go in the shower/bath and I don’t get in the pool with it. The condensation, as of today, goes from the bottom right hand corner to the top left hand corner of the screen. I don’t know what else to do…
07-03-2022 07:28
07-03-2022 07:28
@Rtaras I think your best bet would be to put it in a bag of uncooked rice for longer - maybe 72 hours. Hopefully that will dry it out.
If it has condensation under the screen that would suggest that there is a break somewhere in the seal. In this case I would definitely not wear it in the shower or swimming in the future.
Depending on your area your Fitbit has a 1 or 2 year warranty. If it is still under warranty you may want to get in touch with Fitbit Customer Support on contact.Fitbit.com and include a photograph of the screen in your message.
Best Answer07-03-2022 07:28
07-03-2022 07:28
