09-14-2019 01:40
09-14-2019 01:40
Hi, I just got an Inspire HR but when I downloaded the Fitbit app on to my Windows phone, the Inspire HR trackers aren't on the list of devices you can connect to. Does this mean I can't use this device with the windows app version? Is there any way around it? Thanks!
09-14-2019 03:24
09-14-2019 03:24
Hi @Paul105 I am not sure (having never had a windows phone), but I would assume that you need to set up with a supported Android or iOS phone, but the Inspire may then work OK on your windows phone. Is the phone on the Supported Devices List?
Helen | Western Australia
