03-17-2019
03:09
19:42
DavideFitbit
03-17-2019
03:09
19:42
DavideFitbit
Hi, I was considering buying the Fitbit Inspire HR for my mother but I’m a bit concerned about the screen. According to reviews on the charge 2 hr the screen cracks when it goes above a certain temperature (I believe at about 30degrees) so I was wondering if there was any such problem with the Fitbit inspire hr as she often goes on holiday and the temperature easily exceed this.
Thanks
nas
Best Answer03-17-2019 04:09 - edited 03-17-2019 04:15
As far as I'm aware the screen cover on the Inspire/HR is plastic. It certainly is on my Inspire, so I would assume the HR version to be the same?
According to the user manual the device has an operating temperature window of -10° to 45°C (14° to 113°F).
03-17-2019 03:40 - edited 03-18-2019 11:35
Hello @Nasg and welcome to the forums. I believe the Inspire/Inspire HR have Gorilla Glass face, different from the Charge 2. The specs give an operating temperature up to 45C.
I'm confident the Charge 2 cracking was more isolated than it seems from posts on the forum. I would have gone through a Charge 2 a day for much of my summer.
Update 3/18: Sorry that I was incorrect about the screen material. After much searching, a review on ZD Net called it a glossy plastic screen.
Laurie | Maryland
03-17-2019 04:30 - edited 03-17-2019 04:30
I live in Australia and though I am in the South we have plenty days WELL over 30 degrees and none of my fitbits have cracked a screen, either gorilla glass or plastic!
And, yes, the HR screen is plastic.
Helen | Western Australia
