02-25-2024
08:23
02:24
02-25-2024
08:23
02:24
My do not disturb will not stay off on my inspire 2. Every time I attempt to move away from that selection it turns the DND back on. Any ideas on what I’m doing wrong?
02-25-2024 09:20
02-25-2024 09:20
Make sure you are not accidentally in 'Sleep Mode'. Got to 'Quick Settings' by Pressing both side buttons a few seconds and look for the half moon icon.
02-26-2024 02:31
02-26-2024 02:31
Hi there, @Mabuster. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, it's sad to hear that your Inspire 2 is going back to the DND mode despite you trying to turn it off. We're here to help you with this.
I agree with @JohnnyRow, as it is very likely that sleep mode is turned on (which keeps DND on). Have you tried just tapping sleep mode to turn it off? When I had this issue, I was tapping all the options because I didn't know what was going, until I just tried turning off sleep mode, and that was it, my issue got solved. Would you mind double checking that?
If the above doesn't help, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Nevertheless, I've seen you contacted our Support Team after posting here and they've already assisted you. If the steps that our team has provided did not work, please feel free to contact them back for further assistance. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
