03-14-2019 17:28
03-14-2019 17:28
The app tracks the hours when I meet 250 steps, but the next day when I check my weekly/monthly stats it shows zero. Was working fine until about 10 days ago. Can still see the history from the time when it was working. Tracker is about a month old.
Best Answer03-22-2019 11:29
03-22-2019 11:29
@KWhimsy Welcome to the Fitbit family! Thanks for taking the time to post your experience on this regarding the Fitbit Inspire HR not showing the hourly activity and daily goal streak correctly.
In this case, if you haven't done so already, I'd recommend updating the Fitbit app to its latest version and confirm if your Fitbit Inspire HR is up to date too: How do I update my Fitbit device? This should certainly help you out with this. And as a last resource, you can also try to restart your Fitbit with these steps.
If you keep experiencing the same afterwards; please let me know.
I'll be around! ![]()
Best Answer04-20-2019 13:44
04-20-2019 13:44
This is happening to me too.
Best Answer04-30-2019 02:09
04-30-2019 02:09
This is happening to me as well, got all 9 steps per hours yesterday on the tracker, only showed 2 achieved on the App and Web.
04-30-2019 05:57
04-30-2019 05:57
04-30-2019 14:32 - edited 04-30-2019 14:34
Welcome to the Forums @Skodadet. My apologies for the delay. @DicyOne thanks for joining this family, hope you like what find here!
As our good friend @KWhimsy suggested, you can follow the steps on my previous post to update the Fitbit app or try some troubleshooting steps to fix the issues with your hourly activity.
Let's give it a try and please keep me posted.
Best Answer05-08-2019 06:40
05-08-2019 06:40
Thanks for your reply @YojanaFitbit, my phone app is up to date and the problem first started after the last tracker update. I did turn the tracker off and on again, which did fix the problem for a couple of days, but the app has gone out of sync with the tracker again. Obviously I can keep turning it off again to correct the issue, but it's not good if that only fixes it for 2 to 3 days at the most.
Best Answer05-10-2019 06:42
05-10-2019 06:42
I've made sure the app is up to date and restarted my Fitbit inspire HR but this hourly activity record is still not working. It works for the current day but anything previous shows 0 of 9 activity.
06-14-2019 10:20
06-14-2019 10:20
I am also having this problem. Any permanent fix on the way? Everything is up to date here.
Best Answer06-14-2019 13:28
06-14-2019 13:28
Hey @DicyOne @Skodadet and @isahdr thanks for checking the suggested steps. Sorry for the delay.
I'd like to know what model device are you using to see your stats? This information is really important for us. @DicyOne if you're Fitbit is having a hard time syncing all stats you can try the suggested here.
I'll be around.
Best Answer06-15-2019 08:44
06-15-2019 08:44
Best Answer07-03-2019 07:16
07-03-2019 07:16
Hi @YojanaFitbit, my device is an iPhone XS, it is only the 250 steps per hour that doesn't sync properly every thing else is fine. For now I've just removed the tile from my app dashboard, doesn't stop me using the step reminder on the fitbit. I have a colleague with the same phone and the same fitbit, who has no problem with the 250 steps per hour syncing, so I guess it's just a random glitch.
Best Answer10-22-2019 14:38
10-22-2019 14:38
This has been happening to me too on Inspire and Charge 2. At least once a week I loose one or two of my hours of 250 steps. Have tried restarting everything without any change. VERY FRUSTARATING! About to switch to a Garmin!!
