03-28-2019 05:53
03-28-2019 05:53
Hi,
Does the Fitbit Inspire HR tracks sleep at daytime? It’s because I need to rest in the afternoon...
cheers
Roy
Best Answer03-28-2019 06:16
03-28-2019 06:16
Yes it will track your sleep in the daytime - but (there is always a but) you need to sleep a minimum of 1 hour for the auto tracking to start or you can go to your phone app and on the dashboard tap on the sleep tile then on the sleep page tap on the + sign on the upper right and start your sleep manually. You won't see sleep stages unless you sleep for something like 2 hours continuously.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
03-28-2019 06:16
03-28-2019 06:16
03-28-2019 07:59
03-28-2019 07:59
Thank you 😁👋🏻
