03-06-2020
18:43
16:29
RicardoFitbit
03-06-2020
18:43
16:29
RicardoFitbit
I have the box, but nothing has ever been inside it.
07-22-2020 14:02
07-22-2020 14:02
08-07-2020
12:40
06:14
DavideFitbit
08-07-2020
12:40
06:14
DavideFitbit
I have the same issue. Each morning I have to go to phone settings, select 'Apps & Notifications' then select 'Fitbit' then select 'Storage & Cache' then select 'Clear Cache'.
My oxygen data from the last night always appears immediately when I do this. Hope that works for you as well.
For me I have to close the app, open phone settings, select Apps, select Fitbit, select Storage & cache, then l Clear cache. The oxygen graph always shows data when I reopen the app. I have to do this every day to see that data.
Moderator edit: merged replies
08-07-2020 13:29
08-07-2020 13:29
08-14-2020 05:34
08-14-2020 05:34
Hi Sunset Runner.
I notice you said yours started working. I have a similar problem: oxygen variation just stopped appearing recently on my Charge 3. Was there something you found helpful? I appreciate your time
08-14-2020 05:41
08-14-2020 05:41
08-18-2020 04:51
08-18-2020 04:51
My Charge 3 stopped showing the oxygen variation on 8/2. Box is still there but blank. None of the answers have worked. Is anyone at Fitbit working on this issue and is there a fix that works?
08-18-2020 05:01
08-18-2020 05:01
I tried the cleaning of the sensors with just a soft cloth, placed on the charger and pressed and held the side button until it reset. Was back to normal the next morning
08-31-2020 08:29
08-31-2020 08:29
What was the problem? I'm having the same issue and can't seem to find any help.
08-31-2020 17:18
08-31-2020 17:18
09-02-2020 11:07
09-02-2020 11:07
09-10-2020 05:46
09-10-2020 05:46
Wait, so what's the reason that your light wasn't working? Mine (versa 2) has stopped giving me data too!
09-10-2020 06:20
09-10-2020 06:20
11-27-2020 06:10
11-27-2020 06:10
My Charge3 no longer showing my O2 Chart. Possibly from iPhone update last night?
12-01-2020 07:28
12-01-2020 07:28
Perhaps try a reboot on the watch, just in case?
Not sure why an update would cause a communication error, but then, why would something like changing the clock face display shut down oxygen variations?
04-01-2021 04:04
04-01-2021 04:04
I don't understand how this is the best answer. It doesn't answer the question at all. ???
04-01-2021 04:05 - edited 04-01-2021 04:08
How is this the best answer? And why does the thread have to be about only one version?
04-01-2021 06:47
04-01-2021 06:47
I updated the Fitbit app (Android) 3/31/2021) and no longer see oxygen variation box.
04-01-2021 22:25
04-01-2021 22:25
Hello I have a verse 3 I only joined Fitbit yesterday
My C02 part doesn’t work ?
also I realise I have to open the app to find out thing like how did I sleep as it hasn’t functioned with the watch until I do so ?
I find this strange as before this watch I had a cheap 40 pound smart watch and I didn’t have to do that. Can you please help me to find a solution to this if there is one
04-04-2021 09:08
04-04-2021 09:08
I am experiencing the same issues with my Versa 2 beginning about 1 week ago after working great. No longer getting oxygen readings with the sleep info.
04-05-2021 08:39
04-05-2021 08:39
Did a forced reset of the watch (holding down the side button until it turns off). The oxygen info came back on my app for today and all the missing days.
