06-04-2019 12:11
06-04-2019 12:11
I entered roller blading from 5:41 a.m. to 5:15 a.m. and my dashboard shows that I did it for over 300 minutes. What am I doing wrong.
Also, my active minutes always show as 0 and I've logged plenty of exercise.
And finally, is there anyway to set the Inspire HR to 'know; what exercise you are doing or do you have to set it on the tracker?
06-05-2019 07:57
06-05-2019 07:57
@cabartruff Welcome! It's great to see you around!
Let me help you with your exercise time, active minutes and activity detection.
1.- For the time you are stating you would have been doing this activity for almost 24 hours (5:41 to 5:15 the next day still I believe this is a typo). You can delete this activity and re enter it following these instructions.
2.- Active minutes aren't from the activities you logged but for the intensity of the activity. You can read how these are calculated here.
3.- You can use the SmartTrack feature and configure it following these instructions.
Let me know how it goes.
06-05-2019 09:20
06-05-2019 09:20
1. Yes, that was a typo. I entered 05:41 a.m. to 06:15 a.m. and when I look at my dashboard it shows 375 minutes. When I drill into that activity, the times I entered appear to be correct. I think I built the actual activity incorrectly but I can't figure out where I go to change THAT!
2. I have the auto recognition set up but it still didn't detect this exercise.
3. I want to define roller blading as an exercise shortcut but when I go into that it doesn't appear there is a way to customize the options in there.
