09-24-2019
03:40
05:35
YojanaFitbit
09-24-2019
03:40
05:35
YojanaFitbit
Hi All,
I am using Fitbit Inspire. It counts steps even when I am putting my son to sleep.
I pat my son when I put him to sleep, Fitbit counts the hand movements as steps.
Kindly let me know how do I resolve this.
Thanks & Regards,
Deepti
09-24-2019 05:35
09-24-2019 05:35
Hey @deep_ti_rao, welcome to the Community Forums.
Thanks for reporting your inquiry about the extra steps that you're getting when patting your son.
You might get a few extra steps from arm swings since your tracker will sense the movements of your hand. So, as a friendly tip I suggest to wear your Inspire in your non dominant arm. It's important to specify whether you wear the device on your dominant or non-dominant wrist during setup, but you can do so on your Fitbit app:
To start, the Wrist setting is set to non-dominant. Change your wrist setting in the Fitbit app > Account > Inspire > Wrist Placement. You can find this information other important facts about Fitbit accuracy here: How accurate are Fitbit devices?
If you want to remove extra steps from your daily total check this information: How do I edit or delete Fitbit data and activities?
Feel free to let me know if you have additional questions.
Best Answer09-24-2019 05:54
09-24-2019 05:54
Hi Yojana,
Thanks for the input.
I wear fitbit on my non dominant arm. My wrist setting is set to non dominant.
I will try and set it to dominant.
Thanks and regards
Deepti
