03-26-2020 19:24
03-26-2020 19:24
Hi,
My fitbit is less than a month old and yesterday the screen went black. I have searched the discussion points here and tried each of the suggest hard reboot, charge reboot etc. Since this topic has been going since 2018 there must be a technical issue, any updates??? New ideas to try??
Best Answer03-26-2020 21:32
03-26-2020 21:32
This has happened to me before, when I first had the inspire hr, the screen would go black, it would turn back on within 2 hrs of the screen turning off.... has it turned back on yet??
Best Answer03-26-2020 21:42
03-26-2020 21:42
Best Answer03-27-2020 05:12
03-27-2020 05:12
Mine has the same problem. I have had it for a few months. About once a month it does that. I have no idea why.
Best Answer03-30-2020 22:04
03-30-2020 22:04
Thank you. Yes after using several of the fix options several times, it simply restarted randomly 40 minutes after I gave up...weird as
