10-11-2019
05:23
10:48
YojanaFitbit
10-11-2019
05:23
10:48
YojanaFitbit
I just added a new Inspire HR to my Fitbit account using my son's smartphone, but I have used the Dashboard and Fitbit Connect to sync my tracker on my Mac computer as I do not use a smartphone. To get the new Inspire HR to sync using Fitbit Connect, I need to setup the new device using that software. However, when I follow the prompts to setup, the Fitbit Connect screen shows a blank screen once I have selected the Inspire HR to setup. The window only shows the Next and Back buttons at the bottom along with the four dots to keep track of the steps in the setup. This seems like a software compatibility issue. I am running MacOS 10.12.6.
10-13-2019 10:46 - edited 10-13-2019 10:47
Hi @steven73, welcome to the Community Forums. Thanks for sharing all those details about your new Fitbit Inspire HR.
You did a great job setting up your Inspire HR on your song's smartphone. You don't need to setting it up on your Mac computer. In this case, I'd recommend to go to the Bluetooth settings on your son's phone and "disconnect"
o "forget device" from there. This will avoid future syncing issues with your computer.
Then on your Mac computer:
If you keep having issues syncing with your Mac computer check these syncing troubleshooting steps:
I'll be around in case you have more questions.
Best Answer10-20-2019 05:19
10-20-2019 05:19
After following these directions, I still get the "Not Working?" window in Fitbit Connect. My Inspire HR is very close to my computer, it is not connected to another device nor are there other trackers nearby. I have used Fitbit Connect to sync my old Charge 2, so I know it has worked before.
10-23-2019 11:19
10-23-2019 11:19
Thanks for trying the suggested steps @steven73. Since this is not working, I've requested a case on your behalf. Our team will be getting back to you shortly via email.
Let me know if you have questions about this.
Best Answer12-26-2019 10:42
12-26-2019 10:42
Any updates on this? It's almost 2020!
05-28-2020 09:06
05-28-2020 09:06
Inspire is NOT supported by Mac.(according to product manual) But Customer Support will not outright tell you that, instead try to convince you to use a smart phone. They may also straight up lie to you and say it IS supported but still try to get you to setup/connect via smart phone.
