01-01-2022
13:36
23:01
01-01-2022
13:36
23:01
I have tried all of the solutions suggested on the forum but it is still not working. I will leave it now until tomorrow and hope that the problem self corrects overnight.
1. Tracker is charged and is set to on wrist.
2. Heart rate is being monitored.
3. Am wearing it on non dominant wrist correctly.
4. Have restarted tracker.
5. Points look fine.
6. have changed sleep setting to sensitive.
01-01-2022 16:09
01-01-2022 16:09
I have the same issue. Rebooted the tracker, then restarted the IPhone when I noticed that the app showed that fully charged battery was at 11% after a few forced synchs. That fixes incorrect battery charge but still no sleep data.
01-01-2022 19:30
01-01-2022 19:30
This is very frustrating for me, also. I hope there is a fix, soon
01-02-2022 01:08
01-02-2022 01:08
I am having the same problem over the last two days also not showing heart rate
01-02-2022 04:27
01-02-2022 04:27
Mine tracked sleep for a day or 2 and then stopped. I disconnected it from the app and started again. That worked. For 2 days. Now it has stopped tracking sleep again. I’m beyond frustrated.
01-02-2022 06:05
01-02-2022 06:05
Same situation here. It worked for one night and since then it has not given me a sleep score. It does track my awake and restless times but no sleep score.
01-02-2022 07:06
01-02-2022 07:06
2350
Thank you for being so concise in the information you gave Fitbit. I too am having the same problem as others who have replied to your message. It would be nice if someone from Fitbit would address our problem.
01-02-2022 07:17
01-02-2022 07:17
I got mine for Christmas. Charged and got it set to go that day. It accurately tracked my sleep for seven nights. The last two nights it says that it can’t accurately track my sleep cycle. I’m sorry it isn’t working for you, but it seems a lot of us are having the same issues !
01-02-2022 09:24
01-02-2022 09:24
Very frustrated
ready to send back
can’t read sleep
wrist flick works then doesn’t work
01-02-2022 11:25
01-02-2022 11:25
Morning,
I tried the sync trick outlined on YouTube by Worldoftech, he offers it as a fix for multiple types of fitbits. It worked, I had a sleep score this morning, but it is a fix that has to be repeated every night before going to bed.
Two points. When I checked my Fitbit on waking I got a false error message that the app on my iPad could not sync to my tracker. There was no problem with syncing and I saw a sleep score on the tracker.
When I checked the app there was a sleep score but the detailed info did not appear straight away. I was prompted to add a sleep log. I ignored this and persisted with trying to access the data from the sleep score and eventually it worked.
This suggests to me that this aspect of the Fitbit software is imperfect. Mine is still under warranty so am wondering if I should return it and but another brand of device.
01-03-2022 06:40
01-03-2022 06:40
I saw this suggested somewhere and tried it last night. I did not start the sleep mode and this morning I woke up and received a sleep score, along with all the data on deep sleep, rem, etc. So try that if we don't hear from support about how to fix this issue.
Best Answer01-03-2022 14:12
01-03-2022 14:12
Best Answer01-03-2022 17:51
01-03-2022 17:51
Best Answer01-03-2022 17:54
01-03-2022 17:54
Best Answer01-03-2022 18:26
01-03-2022 18:26
Best Answer01-10-2022 21:19
01-10-2022 21:19
Hi there everybody. Welcome to the Community Forums.
Thanks for trying to troubleshoot your Inspire 2 before reaching out. I recommend considering the following in order to get sleep stages:
Hope that helps.
Best Answer01-12-2022 22:14
01-12-2022 22:14
This is my 2nd Fitbit and most frustrating. It recorded fine for the first few weeks then stopped recording sleep. Also stopped accurately syncing battery life with app. I have tried all the suggestions and still nothing. I have been able to unlink the device with the app and relink it to solve the battery issue. Never had problems like this with my other Fitbit Charge 3
01-17-2022 12:37
01-17-2022 12:37
Hi there, @Pappaw4. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out. I understand where your concern is coming from.
If you've already tried the suggested steps above, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
About your battery percentage inquiry, please check the information provided here: Battery level won't update on Fitbit app after syncing.
We hope your issue is solved soon.
Best Answer01-18-2022 06:20
01-18-2022 06:20
Mine was fine but now registrado time I went to sleep incorrectly and will not accept modifications
Best Answer01-28-2022 17:56 - edited 01-28-2022 17:59
Hi there, @Pennyhgon. Welcome to the Community Forums. Thanks for reporting the issues with your sleep details and for trying to troubleshoot it beforehand.
If you've already tried the suggested steps here. It's best to chat with us online or give us a call. Click here to get connected.
