11-18-2022
17:27
20:58
11-18-2022
17:27
20:58
My Fitbit Inspire 2 turned off in the middle of the night so I initially thought it needed to be charged. When connected to the charger, it pulses and the screen turns on then off, on then off, over and over. It's like the side buttons are repeatedly being pushed. The watch won't stay on if not connected to the charger even though it is 100% charged. It was working fine when I went to bed and doing this in the morning when I woke up. What can be done to fix it? I can't reboot because its like the buttons are already being pressed over and over. 😫
Moderator edit: format
12-01-2022
06:02
08:46
12-01-2022
06:02
08:46
Welcome to the Community forums, @Miss_Jeeky.
Thank you for sharing that you've having this inconvenience with your Inspire 2 device and that you already tried a few troubleshooting steps.
If you you continue to experience the same problem, please try these steps that have been useful for other users experiencing something similar:
Hope this helps, I'll be around.
16:38
09:48
DavideFitbit
12-04-2022
16:38
09:48
DavideFitbit
I am not able to do any of those steps as the buttons on the device are not responsive and the screen turns on and off over and over. Restarting hasn't fixed it. I ended up buying a new Fitbit.
09:48
08:45
12-22-2022
09:48
08:45
@Miss_Jeeky I'm sorry to see that it wasn't possible to complete the steps, but thanks for taking the time to share your feedback about this and for confirming that you're now using a new device.
See you around in the Community.
Best Answer12-23-2022 08:54
12-23-2022 08:54
For anyone seeing this is the future, I had the same issue as above and found that plugging the Fitbit into a higher powered USB charger and then holding the buttons fixed it.
12-31-2022
10:24
08:45
12-31-2022
10:24
08:45
Welcome to the Community forums, @StartPoint.
Thanks for sharing your experience with this. I'm sure it will be useful for other users as well.
