12-10-2020
13:18
10:57
SilviaFitbit
12-10-2020
13:18
10:57
SilviaFitbit
My Fitbit inspire 2 wont hold charge for more than 5 hours and my screen keeps flashing. I’ve tried every tip in this forum to no avail.
12-11-2020
11:15
11:00
12-11-2020
11:15
11:00
@Orod392 A warm welcome to the Fitbit Community. Thank you for the details mentioned.
I appreciate the troubleshooting tried prior to posting. I'd like you to confirm that you followed these tips to extend the battery life of your tracker.
Also double check if you have a Fitbit Inspire 2 as you posted on the Inspire and Inspire HR board.
I'll be around if you have any additional questions.
23:56
06:21
AlvaroFitbit
12-11-2020
23:56
06:21
AlvaroFitbit
its the inspire 2, I’ve tried everything and it just keep dying with hours
Moderator Edit: Formatting
12-15-2020
06:23
11:00
12-15-2020
06:23
11:00
@Orod392 thank you for troubleshooting this issue.
I was going to create a ticket but noticed that you already have one with Support. Please work with them to find a solution.
Let me know how it goes.
Best Answer05-25-2022 18:58
05-25-2022 18:58
Hi, I don’t have a ticket and I have the same problem. Inspire 2, won’t hold a charge. I’ve tried everything. I’ve reset it, I have charged it through my computer; everything that was suggested online, I’ve tried. Please help!
08-01-2023 12:24
08-01-2023 12:24
I have same problem with my inspire 2 and only bought it in March this year. How did you resolve your issue please.
Best Answer08-01-2023 12:26
08-01-2023 12:26
I need help with my inspire 2 aswell. It won’t hold charge for more than 4/5 hours. Only bought it March this year too. Please help
Best Answer08-01-2023 14:19
08-01-2023 14:19
The Inspire 2 is defective. I have had the most unpleasant experience using it. Customer care is also not helpful
08-02-2023
06:08
09:19
EstuardoFitbit
08-02-2023
06:08
09:19
EstuardoFitbit
Unfortunately, there's nothing you can do. The Inspire 2 is a faulty product and FitBit would not replace it when I contacted them. They offered a 30% discount on a new tracker. I researched a lot of trackers after that, but still ended up buying another Fitbit because it was the best fit for what I wanted...and it got the best reviews. I now have a Charge 5 and am very happy with it. I purchased the protection plan, just in case. Crossing my fingers it lasts. Good luck.
See above.
Moderator Edit: Merged replies
