Fitbit Inspire HR screen won't power on or charge
During the update Fitbit screen went black. Now it won't charge or power on
1 REPLY 1
@ABACON25 It's nice to have you on board!
Let me help you with your Inspire HR not working. Not sure if this is a charging or screen issue so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
Alvaro | Community Moderator
