05-19-2020 06:04
05-19-2020 06:04
I've seen another topic about this, but everyone elses still vibrates when charging and some just show the smiley face and nothing else. My boyfriend's doesn't turn on AT ALL. Wont charge, no vibration, no smiley face... Nothing. Does not work at all.
I saw one of the moderators suggested to press the button for 5 seconds when on charge, but that doesn't work either. Does anyone have any suggestions? He's had it less than a year.
05-21-2020 10:44
05-21-2020 10:44
@XenaD It's good that the community is growing! Sorry for the delay in my reply.
Let me help you with your Fitbit Inspire not turning on and thank you for troubleshooting this issue. For your boyfriends tracker since it isn't charging I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
05-21-2020 10:44
05-21-2020 10:44
05-21-2020 13:39
05-21-2020 13:39
It still won’t work and doesn’t connect snugly to charger I have taken your advice, I’m pretty disappointed
05-22-2020 06:46
05-22-2020 06:46
Hi! I clicked on the last link the moderator sent and the solutions they give on there have actually helped more than any other solutions I've seen!
05-22-2020 06:48
05-22-2020 06:48
The last link you attached was actually very helpful! It's now charging. Thank you!!
05-25-2020 10:19
05-25-2020 10:19
@RalphieG13 It's good that the community is growing! Sorry for the delay in my reply.
Thank you for following my previous suggestions. As @XenaD says there are additional instructions in the links I provided but I also have created a ticket so our Support team can further assist you via email.
07-05-2020 10:57
07-05-2020 10:57
I tried all the recommendations listed but my inspire still wont turn on. Please help. Do these fitbit inspires last more than a year?
07-05-2020 14:11
07-05-2020 14:11
I bought mine exactly a week ago and the thing crapped out on me this tuesday- wednesday
07-05-2020 14:21
07-05-2020 14:21
07-05-2020 21:00
07-05-2020 21:00
I've had mine for 3 weeks and today it crapped out. Fully charged, won't turn on, tried to reset, nothing.
07-05-2020
21:58
11:50
AlvaroFitbit
07-05-2020
21:58
11:50
AlvaroFitbit
it’s happening to everyone, since the software upgrade 😑 even me!
Moderator Edit: Formatting
07-06-2020 11:22
07-06-2020 11:22
It's ridiculous. I should've just bought the apple watch. 😒🙄
07-06-2020 11:56
07-06-2020 11:56
@George0us @SunsetRunner @RedGhost77 @SuperBoy Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Inspire screen not turning on. @George0us @SunsetRunner @SuperBoy since you didn't specify if you tried any troubleshoots or which ones you tried I suggest you restart your tracker following these instructions. After this try changing the clock face if the tracker is still syncing.
@RedGhost77 I have created a ticket so our Support team can further assist you via email.
07-06-2020 13:38
07-06-2020 13:38
Ive tried all the articles you and other moderators have given me and nothing has been done. The darn thing just smiles at me and turns right back off even if its been charging for 30 mins.
07-06-2020 15:14
07-06-2020 15:14
I've followed all the care instructions/troubleshooting suggestions and nothing has helped. I've only had this fitbit for about 6 months. It won't turn on, there is no display and doesn't even vibrate when I connect the charger. It's still under the two year warranty...how do I file a claim to have it repaired or replaced?
07-07-2020 00:49
07-07-2020 00:49
07-07-2020 17:46
07-07-2020 17:46
Thanks but mine came back automatically yesterday 🙂 I did nothing to fixed it so it is a bug.
07-08-2020 08:16
07-08-2020 08:16
Lucky you. I try to update mine but it won’t connect. It’ll show a line on the fit bit but will fail. I’m just gonna return my product and get the Apple Watch instead.
