03-20-2022 15:13
03-20-2022 15:13
Hi!
I've noticed today that my inspire screen won't scroll through stats. I can use the side button to activate the screen but none of the touch screen facilities are working
I've reset it but it didn't help, any suggestions?
03-22-2022 06:26
03-22-2022 06:26
I have the same problem going on . It use to scroll but now all the sudden it wont scroll down or up at all. Did you get any help with yours?
03-22-2022 09:44
03-22-2022 09:44
I have the same issue…when I try to contact Fitbit directly I keep getting disconnected
Has anyone heard of any issues on their end?
03-22-2022 10:02
03-22-2022 10:02
Unfortunately I've had no response... I've disconnected and reconnected it to my phone and reset it numerous times but nothing yet 🤔
03-22-2022 19:29
03-22-2022 19:29
I am having the same issue. Try to restart the inspire 3 times. Deleted and re paired the device, nothing is working
03-27-2022 23:04
03-27-2022 23:04
I have the same problem. Had it before and could reset but won't work anymore
